Just a basic streaming build I am working on right now using integrated graphics.
AMD Ryzen 3 2200G 3.5 GHz Quad-Core Processor
Gigabyte B450 AORUS ELITE ATX AM4 Motherboard
Corsair Vengeance LPX 8 GB (1 x 8 GB) DDR4-3000 Memory
Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive
Cooler Master MasterCase H500 ATX Mid Tower Case
Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply
Dell SE2417HG 23.6" 1920x1080 60 Hz Monitor
Logitech G413 Carbon Wired Gaming Keyboard
Feedback would be appreciated!
Gaming PC
CPU: Ryzen 3700X GPU: EVGA 2060 Super XC Ultra Gaming MB: MSI Prestige X570 Creation
RAM: G.Skill Trident Z Neo 2x 16GB DDR4-3600 CL16 NVME: Samsung 970 Evo 250GB M.2-2280
PSU: SeaSonic PRIME Gold 1000w Case: Corsair 680X RGB Black
NAS/Media Box
CPU: Ryzen 3200G  MB: Gigabyte Aorus B450 Elite
RAM: 16GB (2x 8GB) Corsair LPX DDR4-3000 M.2: WD Blue 500 GB
PSU: Rosewill Photon 850W 80+ Gold Case: Cooler Master HAF XB Evo
https://linustechtips.com/topic/1150126-basic-streaming-build/
1 minute ago, GoldenLag said:
budget?
I am trying to keep it below 1000, as I spend about 100-200 per paycheck to get parts and I am buying over the next few months. I am also going to upgrade it with parts from my main computer once they are upgraded and replaced later this year and next year.
Gaming PC
NAS/Media Box
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254158
I also already have the MB and case, but the other parts are still kind of up in the air.
Gaming PC
NAS/Media Box
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254162
do you have the option to return the motherboard?
pick up this GPU:
https://www.evga.com/products/product.aspx?pn=06G-P4-2068-KR
and then go for this:
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($179.99 @ Best Buy)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($84.99 @ Amazon)
Memory: OLOy 16 GB (2 x 8 GB) DDR4-3200 Memory  ($61.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive  ($129.99 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Corsair)
Monitor: AOC C24G1 24.0" 1920x1080 144 Hz Monitor  ($144.99 @ Amazon)
Total: $661.94
Generated by PCPartPicker 2020-01-29 02:27 EST-0500
if you cant return the motheboad, you either need to get a vendor to update the Bios, or order a bootkit. or we can change the build.
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254173
I have a 1500X sitting around I can use to update Bios, so that's not really an issue for me.The monitor and case I just have sitting around as well, so I might as well just use those. I already have a main computer to play the games on, this one is mostly to hold a capture card and upload to Twitch. The MB I have does say Ryzen 3000 ready, so I am not sure if that means the Bios are already updated, or if I need to do it myself.
Here is my main build currently:
Type Item Price
CPU AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor Purchased For $0.00
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler Purchased For $0.00
Motherboard MSI X470 GAMING PLUS ATX AM4 Motherboard Purchased For $0.00
Memory Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory Purchased For $0.00
Storage Samsung 970 Evo 250 GB M.2-2280 NVME Solid State Drive Purchased For $0.00
Storage Samsung 860 Evo 500 GB 2.5" Solid State Drive Purchased For $0.00
Storage Samsung 860 Evo 1 TB 2.5" Solid State Drive Purchased For $0.00
Storage Western Digital Blue 2 TB 3.5" 5400RPM Internal Hard Drive Purchased For $0.00
Storage Seagate BarraCuda Pro 8 TB 3.5" 7200RPM Internal Hard Drive Purchased For $0.00
Video Card EVGA GeForce RTX 2060 SUPER 8 GB XC ULTRA GAMING Video Card Purchased For $0.00
Case Corsair Crystal Series 680X RGB ATX Mid Tower Case Purchased For $0.00
Power Supply Rosewill 850 W 80+ Gold Certified Fully Modular ATX Power Supply Purchased For $0.00
Operating System Microsoft Windows 10 Home OEM 64-bit Purchased For $0.00
Case Fan Corsair ML120 PRO RGB (3 pack w/Lighting Node PRO) 47.3 CFM 120 mm Fans Purchased For $0.00
Monitor Dell SE2417HG 23.6" 1920x1080 60 Hz Monitor Purchased For $0.00
Monitor LG 34BL650-B 34.0" 2560x1080 75 Hz Monitor Purchased For $0.00
Keyboard Corsair K95 RGB PLATINUM Wired Gaming Keyboard Purchased For $0.00
  Prices include shipping, taxes, rebates, and discounts
  Total $0.00
  Generated by PCPartPicker 2020-01-29 02:36 EST-0500
Gaming PC
NAS/Media Box
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254179
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($78.98 @ Newegg)
Video Card: Zotac GeForce GTX 1660 6 GB GAMING Twin Fan Video Card  ($199.99 @ Amazon)
Total: $675.93
Generated by PCPartPicker 2020-01-29 02:45 EST-0500
just use the 1500x then and use the gtx 1660 for Nvenc encoding.
that or just pick up a cheap GPU as a displayoutput and then use the CPU for enocding. no need to grab a new CPU.
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254192
The capture card I am wanting to get has H.264 encoding built in, and I was thinking about selling the1500X to a friend who is building their first computer, which is why a put a CPU on the list. If I do end up using a gen 3 Ryzen, I can just use the 1500X to flash the bios quickly before I sell it to them.
Gaming PC
NAS/Media Box
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254210
you will probably want to use the CPU/GPU encoding for when you are streaming.
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254212
That makes sense. Once I upgrade my main PC to a 3900X, I will most likely throw the 3700X into this one, so I really need something that can hold me over until then.
Gaming PC
NAS/Media Box
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254216
pretty much any quadcore can do 1080p encoding with no issue, so i wouldnt be concerned about it.
https://linustechtips.com/topic/1150126-basic-streaming-build/#findComment-13254220
