As this is my first pc build I am not too sure if I did this right so I’ll write what iv done so far,
as my pc parts arrived today, a b450 tomahawk max and a amd ryzen 7 3700x.
so I put my ddr4 ram in the mobo a2 and b2 slot as manual says. Then I inserted the cpu it had no physical damage and slotted in with no issues, then I insert my gtx 1660ti pny oc xlr8 fan, as I turn the power on it wouldn’t boot and shown the red cpu led on the motherboard, I have no idea what iv done wrong or what to do if anyone has any idea please mention. Thank you!
https://linustechtips.com/topic/1149900-help-please/
Is all you cables connected properly? Make sure 8pin cpu cable is inserted fully.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1149900-help-please/#findComment-13252231
Did you install your CPU cooler correctly? Sounds like there's no contact between CPU and MoBo, which leads to no pressure on CPU from cooler. Just a guess.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
https://linustechtips.com/topic/1149900-help-please/#findComment-13252232
