I bought a new PC yesterday with this spec:
CPU: AMD Ryzen 7 3700X
MB: Asus PRIME x570-p
GPU: RTX 2060 SUPER
PSU: CoolerMaster 750W
OS: Windows 10 64 bit latest update (checked for updates yesterday)
I connected everything from my previews PC and everything seem to work but the headphones that are connected to the front audio port.
My mic works just fine (also connected to the front panel). Speakers (rear panel) work and TV (HDMI to GPU) works fine. Only my headphones aren't working.
Tried reinstalling Realtek drivers multiple times both from Asus' website and Realtek's.
It seems like it's recognized in the settings (pic)
As you can see, it said "Front panel 3.5mm jack" but no sound.
Anything I can do to fix it? (tried restarting my PC of course)
https://linustechtips.com/topic/1149870-front-headphone-jack-doesnt-work/
did you make sure to actually set it as your ouptut for audio?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Did you connect that part of front IO to your MoBo correctly?
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
i think it was a pre-built, which is why i didn't mention this specifically
Yes
Like GrockleTD said, it was pre-built. But like I stated, the mic is also connected to the front panel and it works and nothing seemed weird when I looked there.
Just now, MattSa said:
Yes
does the rear audio port work properly?
Just now, Sylentic said:
Might be a stupid one but I've seen it happen. Does the device that you plugged in have its own audio controls? Check if its actually turned up or not muted.
Yeah I checked that one too lol.
Those are (cheap) Razer headphones. Checked the volume controls on them
well, if it is a local shop, is having them take a look at it an option?
Open case and check if there is a connector placed on AAFP shown below:
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
It's an option of course I just hoped it's a settings issue I might have missed and would be a 5 minute fix lol.
Thanks! Will check later tonight and give an update
Unless its making direct contact with the fan i would not worry to much. Most motherboards only have a passive heat sink anyway. If the fan spins you will be fine.
Also I'm assuming you already done this but try plugging the speakers (The working ones) from the back to the front and test if sound then works.
  • 3 months later...
hay i'm having a similar problem with my front panel
my lavaliere  mic doesn't work in the front or back when i plug it in to the back i get no sound pick up and in the front it sounds like robot mores code
my earbuds only pick up background in the front jack
i don't know what to do  plz help
