Noob Overclock issue
Solved by Zando_,
Just now, ApexSutton31 said:Okay. So I have a Clear CMOS button the back of the MOBO. Do you just click it at your regular Windows screen? Or do you do it on restart or something? And what does that do? Or should I just look that up?
Turn the PC on, push it right away. Should reboot once or twice itself, then boot normally at bone stock settings.
If it's fucked enough sometimes the clear CMOS button doesn't work, then you turn off the PSU with the switch at the back, remove the CMOS battery, hold the power button for 10 seconds to drain the caps as much as possible, then let it sit for 5-10 minutes. Then put the CMOS battery back in, turn on the PSU, it should boot up with a bone stock BIOS again.
