Hi, I just recently built a new pc and I am not really too informative on much. However, I saw that only one of my cpu cores were at 103 while the others were at around 28ish degrees Celsius. And this was just while the pc was browsing the internet. Is this some sort of bug with the software or is it something I should be worried about? Thanks2072291189_2020-01-26_LI(2).thumb.jpg.051710953fee2c4c193a25d47e55ecac.jpg
https://linustechtips.com/topic/1149452-weird-cpu-temperature-readings/
Measure using HWiNFO. It's much easier to use, and more accurate.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
