I am looking to build my own pc soon as i only have a laptop with an intel core i5-8300U(H?) and a gtx 1050 ti (mobile of course) and i want to be able to run vr. Would these parts be able to run smooth vr at high settings and would you recommend i make any changes? I only have a little bit of budget to move around so please keep it around the same price point.
Edit: part list should no longer be private. i don't know why it was marked as private.
Edited by liamthebeast029
https://linustechtips.com/topic/1149438-first-time-builder-looking-for-help-edited/
49 minutes ago, liamthebeast029 said:
should be public now.
What GPU do you have?
R5 2600 doesn't have integrated graphics.
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
I Have an rx 580 8gb from ebay at this link: https://www.ebay.com/itm/MSI-Radeon-RX-580-8GB-Armor-OC-Graphics-Card/153651417246?hash=item23c656909e:g:1tsAAOSwlLBdUp5f
2 minutes ago, liamthebeast029 said:
the 450W? it's lower wattage and not modular?
550. cheaper and much better quality. even if non-modular. if you want semi-modular, get the corsair tx550m
Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply
I wouldn't really recommend that rx580. The MSI armor OC RX580 runs hot. Also that card can be had brand new for $140 from Amazon.
I'll recommend something like this instead....
PCPartPicker Part List
CPU: AMD Ryzen 5 1600 (14nm) 3.2 GHz 6-Core Processor  ($85.00) The Ryzen 5 1600 AF is available on amazon.com for $85. It is basically a Ryzen 5 2600 with first gen IMC. It is based on 12nm.
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($74.98 @ Amazon)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3200 Memory  ($54.99 @ Newegg) Ryzen loves fast dual channel memory.
Storage: TCSunBow X3 480 GB 2.5" Solid State Drive  ($51.99 @ Amazon) SSD makes overall system way more snappier.
Video Card: Sapphire Radeon RX 580 8 GB PULSE Video Card  ($100.00) RX580 can be had for around $100 on AliExpress with free international shipping.
Case: Aerocool Cylon Mini MicroATX Mini Tower Case  ($38.50 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($39.99 @ Newegg) Comparitively a way better PSU.
Total: $445.45
Generated by PCPartPicker 2020-01-27 10:28 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Total: $445.45
Is there an ssd with a bit more storage that you would recommend? Also i was thinking about a cooler master master box Q300L for the case would that be a bad choice?
Yeah q300l is a pretty good case.
Can go for the 1tb varient of the SSD that I mentioned above.
https://pcpartpicker.com/product/68c48d
Can use this tier list for selecting ssds.
SSD TIER LIST
CPU - Ryzen 7 3700X
Thank you for all of your help. I think that's the build i'm going with.
