Could it be that you have a bad connect USB ports on the motherboard that when you put on the side the slot just makes better contact ?
"Rise red as the dawn" - Scarlet Guard motto (Red Queen Series)
https://linustechtips.com/topic/1149018-usb-port-help/#findComment-13249219
