So some time ago i made a post idk if it was here or another forum but i had inserted a picture of me gpu and cpu usages going up and down constantly ( gou 0-100-0, cpu was going at around 30 up and down) and someone said that my ram was too slow and they told me that ryzen feeds from high speed ram, since i had 2x4gb 2666mhz i decided to upgrade to 2x8 3200mhz but the issue still persists.
Now im starting to suspect the gpu, it might be coming to its end since i bought it from a miner about 1 and a half years ago.
hmmm.png.033d2f898064ced7892507b821028548.png , heres the usage going crazy while playing league of legends with the new ram.
Edit : i must say that the cpu usage has calmed down and is much more stable than before after checking the image again
This is really annoying since this is basically my first build and i want it to work properly.
Well except the gpu that came over from the old build but i think im going to save up for the rx5600 xt since its getting very good feedback.
Ryzen 5 3600 , running at 3.6ghz (pb and pbo disabled since cooler is stock)
b450 a pro max
corsair vengeance 2x8gb 3200mhz
corsair rm650
SAPPHIRE PULSE RX 580 4G G5
https://linustechtips.com/topic/1148839-gpu-usage-still-going-crazy/
