I've recently got myself VPS subscribtion, but for some reason cant connec to it.
I've already watched many videos with possible solutions and ''fixes'' but none worked. I hope you great people of LinusTechTips Forum can help me out find a solution!
Project Redline:
♦CPU: i7-5820k  ♦CPU Cooler: Kraken x61 ♦Mobo: MSI X99A SLI ♦RAM: G.Skill Ripjaws 4x4GB 3200mhz ♦GPU: Evga 980Ti Hybrid ♦Case: NZXT H440 ♦SSD: Samsung 850EVO 500GB ♦HDD: WD BLUE 1TB 7200rpm ♦Display: 1280 x 1024
https://linustechtips.com/topic/1148323-remote-desktop-connection-help/
Recheck your ip address, also first time RDP might have to be initiated though VPS website. What VPS are you using and what version of windows is the VPS running?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
Bought one from A2hosting
VPS operation system is: CentOS7
What should i recheck on the IP adress exactcly and I didnt do any initiation.
Project Redline:
RDP is a windows OS protocol and won't work for CentOS unless you use a third party tool like xRDP that you would have to install into CentOS.
https://draculaservers.com/tutorials/install-xrdp-centos/
To get into CentOS right now you have to use a ssh client such as putty
https://www.putty.org/
Internet Connection
Passmark Score
3dmark Score
Network
This looks like long and complicated process should i just get another VPS with different OS
Project Redline:
Depends what are you wanting to do on the VPS?
Internet Connection
Passmark Score
3dmark Score
Network
I just need the VPS to run Metatrader 4 on it 24/5 without the need of my PC to be turned on constantly
I've though it will be an easier procces....
Project Redline:
Here is Metatrader 4 install on Linux
https://www.mql5.com/en/articles/1358?utm_source=www.metatrader4.com&utm_campaign=download.mt4.linux
If your not familiar or comfortable with command line linux is probably not the OS for you.
Internet Connection
Passmark Score
3dmark Score
Network
This maybe something more to your liking
https://www.routerhosting.com/windows-10-vps/
Internet Connection
Passmark Score
3dmark Score
Network
That looks lovely! And more newbie friendly :))
I've canceled my other VPS subscription and will get this one
Project Redline:
RDP only supports Windows machines! If you're running CentOS youll need to be comfortable with a command-line interface (unless your VPS host provides you with some kind of control panel).
Your best bet is to find a Windows specific VPS, they usually cost a bit more due to licensing fees for Microsoft but easy way to go.
