Best Stable Overclock Settings for i7 9700k?
4 hours ago, Lapjun said:So what if I have an average 9700k? How high can I overclock, and what should I usually set my volts to?
According to https://siliconlottery.com/pages/statistics. I assum an average 9700K is able to achieve stability at 5.1Ghz non avx, 4.9 Ghz avx, using the normal distribution.
The 9700K can turbo to all core 4.6Ghz at stock setting, first find the minimum voltage to boot it at all core 4.7Ghz, with 0 avx offset. ( Remove the limits, sync all mulitpiler to 47, manually override your core voltage), dont tune your RAM yet. Usually i start with 1.22 V for a 9700K, lower for 9900K and even lower for 9900KS. If windows is sucessfully booted, decrease the voltage by 0.01 until it cant boot. If it cant boot from the beginning, increase it by 0.02 and fire another attempt . Remark the minimum "boot" voltage for 4.7Ghz.
Now, estimate the min voltage of your goal by the following: estimated voltage = ( min boot voltage / 4.7 Ghz) * Your Goal in Ghz, always round it up.
i.g, my min boot voltage (4.7Ghz) is 1.20volt, i will start finding the min boot volt (5.0Ghz) at (1.20 / 4.7) *5.0 = 1.28 volt.
Once you remark the min boot voltage for your goal frequency, increase it by 0.03V, run the Intel Processor Diagonostic Tool first, then run some moderate stress test in Intel Extreme Tuning Utility, FPU in Aida64 for at least 15 min to detect if it result to Blue screen of Death. This usually detects severe instability. Increase the voltage by 0.01 if fail.
You can also try finding the min voltage that does not result in instant failure.
In order to emulate the most brutal condition your CPU will face, you need to test whether it can handle the AVX in Prime 95. Increase this voltage by a further 0.3, and run the small FTTS in Prime 95 for at least 20 min. If less than 2 of the workers ( thread ) fail, your CPU is stable in most situation at this setting. If non of them fail at all, your CPU is very close to flawless.
Stop at 1.42V unless liquid nitrogen is involved.
For long daily use, i wont't let the CPU operate at the voltage more than 1.35V; or at the setting that will boil the chip beyond 90 degree during non prime 95 stress test.
Dont even think about modifying the BCLK frequency if you are a beginner. It will directly effect the frequency of ram and pci devices. It is a pro touch.
You will need the luck of getting a top 9% and top 1% silicon quality 9700K to acheive AVX stability at 5.0Ghz and 5.1Ghz.
