Data Drive = System Issue
Go to solution Solved by Mira Yurizaki,
Let's see if this works:
Hey, guys any ideas how to move that System tag into ? ( SSD ) ? Without affecting data/files.
What i've did in the past is relocated my Documents and Videos folder to ? drive in order to save SSD space, tried to reset it back to default, but now as i understand if i gonna disconnect my HDD ( ? ) the OS won't boot, since same happens if i try to make it inactive, there's nothing to boot from OS Drive.
https://linustechtips.com/topic/1148111-data-drive-system-issue/
Didn't work :/
It didn't boot still.
2 minutes ago, Exaco said:
Yes including restart.
Try the following:
  • Make a Windows install media
  • Format Z: to clear it out
  • Shutdown the computer
  • Unplug the HDD
  • Boot the computer with the Windows install media
  • Select "Repair this computer" when you get to the main screen
  • Select Troubleshoot -> Command Prompt
  • Figure out what C:\ and Z:\ are (it may just be D:\ and Z:\). The command prompt may tell you it's on the C:\ drive, but C:\ is really the install media.
  • Do the Bcdboot command again, but replacing C:\Windows with wherever Windows really is (it could be D:\Windows)
  • Try booting again, but leaving the HDD unplugged
41 minutes ago, Mira Yurizaki said:
Try the following:
  • Unplug the HDD
No luck also.
Guess just gonna reinstall the OS w/ HDD unplugged in future.
