Hello guys my old macbook air (2012) recently broke so I decied to take the ssd out of it and put it in my gaming rig for additional storage heres the issue apple nvme ssds are 18+8 pin and I'm guessing my motherboard port is 18+5pin so is there any adapter I could get or any other way I can resolve my problem?
Thank you in advance!
https://linustechtips.com/topic/1146745-help-with-nvme-ssd/
1 minute ago, Electronics Wizardy said:
Thats not a nvme, the 2012 airs had sata ssds.
This should work if you just want a sata ssd adapter https://www.amazon.com/QNINE-Adapter-MacBook-Converter-Support/dp/B06XH7K2C6
Thank you so much lol it looked like one so wasn't sure
https://linustechtips.com/topic/1146745-help-with-nvme-ssd/#findComment-13227196
