Hey guys! My pc is close to finishing. But the front fan is like 3 cm too short. Can i just take a 120mm and hot glue it to the front?
Specifications:
MOBO: AsRock B450 PRO4
PSU: some kind of Corsair 80+ bronze
CPU: AMD Ryzen 5 3600x
GPU Radeon RX590
RAM 16 GB G.skill Ripjaws 3200mhz
Fans: Xilince and Aerocool
https://linustechtips.com/topic/1146299-cooling/
how is it too short? Cable too short? Screws too short?
Desktop benching:
https://linustechtips.com/topic/1146299-cooling/#findComment-13223698
Cable too short
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1146299-cooling/#findComment-13223724
2 minutes ago, Pcnoob745 said:
Cable too short
cant find better positioned fan headers? Use a fan splitter. I dont see why hot gluing a fan will help with this
Desktop benching:
https://linustechtips.com/topic/1146299-cooling/#findComment-13223736
Splice your front fans together. No problem with that.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1146299-cooling/#findComment-13223791
So the original one is 90mm i have a 120 mm lying around
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1146299-cooling/#findComment-13223812
What case you have?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1146299-cooling/#findComment-13223819
4 minutes ago, Whiro said:
What case you have?
I dont know. Its a retired old server case
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1146299-cooling/#findComment-13223826
then why not use the bigger fan? It should give better airflow for the same noise level, points added for not neeing a splitter to connect to the board
Desktop benching:
https://linustechtips.com/topic/1146299-cooling/#findComment-13223861
Yeah but can i hotglue it?
Specifications:
GPU Radeon RX590
https://linustechtips.com/topic/1146299-cooling/#findComment-13223903
hot glue because it doesnt have screw holes for it? Sure.
Desktop benching:
https://linustechtips.com/topic/1146299-cooling/#findComment-13223908
That’s sounds even a little to ghetto for me.. got a pic?
https://linustechtips.com/topic/1146299-cooling/#findComment-13224153
Indeed.
https://linustechtips.com/topic/1146299-cooling/#findComment-13224277
