  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
  Hide contents
R7 3750h with RTX 2060 (1340 USD) Is the faster one. :)
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1146228-need-help/#findComment-13223045
19 minutes ago, jawriper5110 said:
i5 9300h with GTX 1660 ti (1055 USD)
               or
2060 is a bit faster than 1660ti, but it's not worth 300 more. what are the rest of the specs of the laptop? ram, ssd capacity, monitor refresh rate?
https://linustechtips.com/topic/1146228-need-help/#findComment-13223060
it need full spec tho. what if 2060 but the heat management is bad so its slowdown to near 1660ti?
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1146228-need-help/#findComment-13223065
i5 one has 144 Hz 1080p ips display and other two are 120Hz. i5 has 1 tb SSD and rest have 256 gb SSD and 1 the SSD. All three have dual channel 16 gb of RAM.
https://linustechtips.com/topic/1146228-need-help/#findComment-13223087
the i5 one sounds like the best deal then, especially for that 1tb ssd. it's annoying that laptop manufacturers still put hdd's in them.
https://linustechtips.com/topic/1146228-need-help/#findComment-13223095
what models?
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/1146228-need-help/#findComment-13223387
1 hour ago, jawriper5110 said:
Acer Nitro 7
Asus Tuf fx505dv
MSI Alpha 15
Neither models are good
May I know where are you from? Budget?
Desktop specs:
https://linustechtips.com/topic/1146228-need-help/#findComment-13224906
16 minutes ago, jawriper5110 said:
India and budget would be around 90000 INR
Acer Predator Helios 300 PH315-52
Lenovo Legion Y540 15 81SX0041IN / Lenovo Legion Y7000SE customize (1660Ti)
Desktop specs:
https://linustechtips.com/topic/1146228-need-help/#findComment-13224981
