13 minutes ago, Veljko44 said:
Every time, i play 2 or 3 hours and when this happens I have to restart my pc on button.
Try using pre2020 Drivers,..
If still occurring, declock GPU on both VRAM and Core and see if it still happens.
If so, could be a crap GPU or a power delivery bug (being still a GPU issue because RX500 series still take 75w from the PCIE)
More so than the average GPU which is also just as capable of doing so..
But I hear constant horror stories about the RX4/5 series... and I wonder if its that PCIE slot power and some bug...
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222636
RX 470/570 didn't really have any issues.
I wouldn't be surprised if GPU is being killed by that PSU.
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222639
Interesting thing about this is that my gpu is working good and right after clicking my windows button on keyboard it crashes...
 I am not really experienced in this, how I can solve that bug about power...
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222727
if the gpu was damaged by the psu it would be dead rn.
this sounds more like a driver or windows related problem.
i think trying pre 2020 drivers cant be a bad idea.
also after this happens you can take a look in the event viewer
search for event viewer open as administrator go to windows protocols and system and search for problems and warning messages related to the issue
if the video driver crashed or the card has a malfunktion the information will be there.
the problem accouring after the windows button press could suggest its not really about the graphics card and surely not about hardware.
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222881
thank you man!
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222905
When drivers crash, most of the time it's either black or blue screen.
White artifacting screen tends to be a sign of damaged graphics card. Same shit happened to my Vega 56.
Also, card can be damaged without killing it straight away.
Ex-build:
Meshify C – sold
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222918
I have warranty so we will see what's next haha
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222947
well if the card is damaged and malfunctioning the event viewer should list some kind of fatal error from the gpu
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13222949
So when this bug happens to me I have to turn off a pc on button, end when I turn him on again I search event viewer?
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13223036
yes you shut it down and start it normaly ^^ if you go in the event viewer right away the listings should be near the top. click on them and read a little. maybe it says something maybe theres some error codes ^^
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13223236
7 hours ago, Veljko44 said:
Temps are good, not over 60 degrees when I play csgo and 70 was maximum in superposition test.
Its not overclocked.
That's very strange. If everything is fine in the game (I assume you're running full screen) but then the display goes haywire after you exit out, I suspect that the display drivers aren't properly resetting your display to your Windows desktop resolution. I'm leaning towards this being a driver or game issue rather than a hardware issue.
Are you having any issues with other games?
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13223285
To be honest I play only csgo,and it is working well on other gpu so drivers can be a problem
https://linustechtips.com/topic/1146091-rx570-problem/#findComment-13223455
