Ok so i have a kolink observatory case with the standard RGB fans that comes with the case. You also got a fan hub where you Connect the fans to because there are not any fan connectors from the fans just some special type that fits to RGB hubs. And the hub is connected to the PSU with a molex. Right now i cant control the speed in any way but i would really like to do that because right now they are running at full speed. I need some help what do i need??????
https://linustechtips.com/topic/1146072-help-with-rgb-control/
On 1/17/2020 at 8:18 AM, Affe1234 said:
So you can’t have a fan hub that can control the voltage or something?
You can, but if I remember correctly, Kolink fans use proprietary connector. So you can only use them with other Kolink products. If fans would have normal PWM or 3pin, then you could connect them directly to mobo for controls.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1146072-help-with-rgb-control/#findComment-13225816
