I cannot seem to overclock over 4ghz with any reasonable voltage. Running at 4ghz requires over 1.35 volts for me, and trying for 4.1ghz has seen me pushing the voltage over 1.425 with it still crashing in Cinebench R20, even though it will pass in Ryzen Master. I had a stable 1.325 at 4ghz, however, after a few hours of The Forest was not stable in Cinebench and crashed. Any suggestions?
Heat is not an issue if temps are being recorded correctly. Using a B450 Gigabyte board.
https://linustechtips.com/topic/1145926-overclock-problems-ryzen-5-2600/
13 hours ago, RetroGeneral said:
you have failed in the silicon lottery son.....
same here
don't oc it, run fast memory preferably on xmp though really best you can expect is at auto auto auto 2133 mhz
I figured, going to take it back and swap for 2700x
