For context I have a CX550M but only with the 24 pin and 8 pin which come attached. I can’t seem to find cables from the CX550M on eBay but I can find cables for the CX850M and CX750M. Will the cables be compatible for the CX550m? On reddit I was told I should look at a pin out and I think I found what I was meant to be looking for and according to it a lot of the Corsair PSUs have compatible cables or am I missing something?
https://linustechtips.com/topic/1145396-finding-compatible-cables-for-cx550m/
I'm guessing its this PSU
https://www.corsair.com/ww/en/Categories/Products/Power-Supply-Units/cxm-series-2015-config/p/CP-9020102-UK#tab-faqs
are you upgrading your original cables or replacing broken ones
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
I bought it second hand not was being sold with no cables.
There's no need to google for pinouts or forums, when Corsair themselves tells you what cables are compatible:
https://www.corsair.com/us/en/psu-cable-compatibility
CX550M uses Corsair Type 3 SATA/Peripheral cables, and Type 3 or Type 4 PCIe cables.
just messaged them
they are type 3 cables that they sell
Yes, this PSU uses Type 3 cables.  These can be purchased here: https://www.corsair.com/uk/en/Categories/Products/Accessories-%7C-Parts/c/Cor_Products_Accessories_Parts?q=%3Afeatured%3AproductCategories%3ACor_Products_Accessories_Parts_PCComponents_PowerSupplies&text=&pageSize=#rotatingText
Regards,
Victor
Thank you for choosing Corsair.
http://www.corsair.com
https://www.facebook.com/Corsair
https://twitter.com/Corsair
