Hi everyone!
I'm having some issues with an Asus X570-Pro Mobo. I'm trying to connect a corsair rgb fan to it. At first everything went fine, after a bit I started playing around with the HUE on it.
Next day I found out that some of my colors were too dim. I reset Aura Sync to default, it kept being like that. I switched my fan to another RGB header and it worked fine.
My debug mode found this:
  • Blue is shown as proper blue
  • Red is shown pinkish
  • Green is just a super light green
I've tried flashing the bios, Reinstalling Aura, etc..
This are the reasons I've atm...
  • Aura bugged the fuck out of my header. Leading my mobo to being stuck in that hue level
  • Somehow my R and G pink got burnt?
If it's the first case, I'll try more stuff until I fix the bug. I should try doing this on a clean windows installation
If it's the second, I'm worried about my mobo. Should I RMA it?
Thanks in advance!
Edited by Weinrib
Removed ul's
https://linustechtips.com/topic/1145312-rgb-header-issues/
