Hi, really dumb question, but in order to mantain zero rpm mode in a custom fan curve (since default only goes up to 65%), do i only put 0 rpm until like 55C ( is what the default fan curve starts ramping up). My question is because i dont want to harm my hardware putting zero rpm in a custom curve
Main rig: CPU: Ryzen 7 3700X cooled by a Noctua NH-U14S; Mem: 16 GB(2x8) G.Skill TridentZ White 3200 MHz; GPU: EVGA RTX 2070 XC; MOBO: MSI B450 Tomahawk; Storage: XPG Spectrix S40G M.2 512GB SSD; Kingston A400 480GB SSD; 1TB Western Digital Blue HDD; PSU: Corsair CX750M Semi-modular (80+ bronze); CASE: Thermaltake Commander C36.
Secondary rig: CPU: Intel Core i7 4790 @3.60GHz(Turbo @4.00GHz) cooled by Corsair H60; Mem: G.Skill RipJawsX DDR3 16GB(4x4) OC@2133MHz (11-11-11-30 (1.6V)); GPU: None(for now); MOBO: Gigabyte Z87-HD3; Storage:HyperX 120GB; PSU: Thermaltake SmarT series 750w (80+ bronze); CASE: Thermaltake Chaser A41.
https://linustechtips.com/topic/1145102-0-rpm-mode/
Your hardware won't start getting harmed until it reaches around 100C+, that said it normally can't maintain high clock speeds(and yes stock speeds are high) at temps above 60C normally.
No risk of damage just stability and performance at risk
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1145102-0-rpm-mode/#findComment-13213417
My gpu supports 0rpm mode and I was checking today at what temps it starts spinning fans (need it for someone) 65c it starts doing anything with fans but even than it’s not much. Around 72c it’ll rump up to around 55%
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1145102-0-rpm-mode/#findComment-13213451
I dont really like 0rpm mode.  Just my opinion.  I usually have it running at like 25%, and when it starts to get hot, it ramps up.
My build
Ryzen 5 2600 @3.95ghz
Cryorig M9a
Gigabyte x470 Ultra Gaming
Gigabyte RX 590 @1720mhz
2x8 Corsair LPX Vengeance 2933
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
WD Blue SATA SSD 500GB
https://linustechtips.com/topic/1145102-0-rpm-mode/#findComment-13213472
Everyone gonna have different opinion about it. I personally love it, pc is not so noisy and idle temps are not high
                                          WHIRO
https://linustechtips.com/topic/1145102-0-rpm-mode/#findComment-13213528
my windforce fans are quiet below 40, but thats my windforce fans.  what works for u
My build
Cryorig M9a
ASUS Wireless card
EVGA 650GQ
Cougar MX330G
https://linustechtips.com/topic/1145102-0-rpm-mode/#findComment-13213535
