I recently built a new computer and have just finished setting it up, but when I ran cpu-z to make sure that everything was running correct I noticed that my memory was only running at 1066MHz. I have a Ryzen 5 2600, MSI B450 Tomahawk, 16gb(2 x 8) TridentZ Neo ram. I went to my bios and enabled xmp profile 2 which on my board is 3600MHz. I know that it is not likely that my board is rated for that speed, but I at least excepted it to settle in to at least a 3200MHz speed. I am a little disappointed that I am not able to achieve the speed that the ram is rated for due to the constraints of my system, but at the very least Id like to get my memory to a higher speed. Any information would be much appreciated. Thank you.
https://linustechtips.com/topic/1145098-memory-running-at-1066/
1 hour ago, Dabombdiggity23 said:
I recently built a new computer and have just finished setting it up, but when I ran cpu-z to make sure that everything was running correct I noticed that my memory was only running at 1066MHz. I have a Ryzen 5 2600, MSI B450 Tomahawk, 16gb(2 x ? TridentZ Neo ram. I went to my bios and enabled xmp profile 2 which on my board is 3600MHz. I know that it is not likely that my board is rated for that speed, but I at least excepted it to settle in to at least a 3200MHz speed. I am a little disappointed that I am not able to achieve the speed that the ram is rated for due to the constraints of my system, but at the very least Id like to get my memory to a higher speed. Any information would be much appreciated. Thank you.
Where did you check it? Remember that DDR stands for Double Data Rate , so if you see 1066 that means it’s running at 2133 mhz
Are you sure you enabled xmp for ram?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1145098-memory-running-at-1066/#findComment-13213505
