So, I'm on my quest to finally official build my own PC. I've been using a pre-built for awhile now and decided to use my allocated funds to finally make a computer that I can really call my own. Below is the PCPartPicker list I made to show off my plan. I already have the case and the fans, just need to buy everything else.
I've been planning on posting here for awhile, but now I'm finally getting around to it to ask for some guidance. Tell me ANY comments you have regarding my list, all criticism, concerns, and comments are appreciated!
P.S.: I plan to use this for gaming and occasionally school work, and I want to be able to play new AAA titles (and HOI4 which I have around 1,100 hours in) so I thought this setup would be adequate for anything I wanna play and then some.
https://linustechtips.com/topic/1144794-first-official-pc-build/
You can build yourself a WAAYYYY better system in that kind of a budget.
Windows keys can be had fr pretty cheap from sites like eBay, kinguin, scdkeys, etc.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($189.99 @ Amazon)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  ($103.98 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($79.99 @ Newegg)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($66.98 @ Amazon)
Storage: Hitachi Ultrastar 2 TB 3.5" 7200RPM Internal Hard Drive  ($35.95 @ Amazon)
Video Card: ASRock Radeon RX 5700 XT 8 GB Phantom Gaming D OC Video Card  ($379.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Corsair)
Total: $986.85
Generated by PCPartPicker 2020-01-12 22:23 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $986.85
God dammit, you beat me with the exact same setup by 15 seconds.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
Literally any  of these please. ^^^^
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
Total: $986.85
9 hours ago, Daniel Z. said:
So I've opened both of these lists, and for both this first issue popped up.
Not really sure if that's anything to worry about or not just because I know PCPartPicker can be kind of wack when it comes to determining issues and incompatibilities.
Don't worry, either of those boards will support zen2 CPUs out of the box.
Usually most b450 boards don't support zen2 CPUs out of the box. But the new b450 max series boards from MSI comes with out of the box zen2 support.
https://www.msi.com/Motherboard/B450-TOMAHAWK-MAX
SSD TIER LIST
CPU - Ryzen 7 3700X
So what's your final say? Do you think your build is the best bang for my buck? Is there any alternatives that may be better?
