Hello
since i have built my 1st pc about a 1 year ago i have be wondering how i can maximize my airflow
right now this is what a have
case MB530P
front: coolermaster ml360 with 3 2200 rpm fans as intake
top: 2 140mm argb coolermaster fans 1600 rpm as intake
back: 1 120mm coolermaster rgb airflow fan 1200 rpm
this for a 8700k and a gigabyte 1080ti gaming oc
temps idle at 34c for the gpu  and 22C for the cpu
in a game like red dead 2 66c for gpu and 40c for the cpu
my reasoning for this config is the very light airflow that the front fans produce because of the front mounted radiator, and the top fans blow quite a nice amount of air inside the case
but i have been wondering if it would be better to have the top fans as exaust has everyone says you should have ?  But in this case it seems to be working!?
Some advice would be great!!
Thank you!!
https://linustechtips.com/topic/1144749-advice-for-case-airflow/
You could just flip the top fans and see if temps improve.
Top fans aren't probably doing anything right now as you have CPU cooling and main intake at front. The air from top intake doesn't make it to GPU to be effective and it isn't used for CPU cooling at all.
Looking at temps, don't expect any massive changes. You are already really good with air cooled GPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
This, top fans are probably mostly useless in your current setup. Maybe push/pull setup on the rad will improve temps slightly, but it probably won't be worth the cost.
