What are the temperatures like? Some graphics cards have a 0 rpm fan mode when the gpu is cool enough.
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205359
1 minute ago, Black_Wolf said:
Even if i start a game wont make them start spinning.
Give it a minute or two. When the GPU gets hotter the fans should start spinning.
Can you check the temps of your GPU? Use HWInfo or something so it shows the accurate temps. If it still doesn't spin even at high temps, your fans are probably busted or something else.
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205374
If you do rule out what the others are saying, I would pull the card out and verify the fans on the card are plugged into the their header on the video card. I think it's a small chance that came unplugged, but it'd be something to check.
If it turns out your fans died, you may look at swapping it out for a AIO watercooling solution using the NZXT Kraken G12 and any of the compatible coolers. That'd only cost you ~$100 vs buying a new card.
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205387
i just tried and it got up to 65 degrees and still not spinning, i dont think the fans are faulty because they work they spin with afterburner
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205408
Do what @Spaceman_Wil suggested on the post above. It's most likely the fans might not be connected to the power header or it might be something else entirely.
私はオタクではありません。
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205414
I don’t think this may be the actual problem. OP mentioned that they do spin when he opens afterburner, that means they work.
what model of that 970 you have?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13205531
2 minutes ago, Black_Wolf said:
Asus strix geforce gtx 970
I have exact same model. They definitely don’t spin when idle but not sure at what temp they start. I’ll check it out when I can and let you know. Did you change any settings in afterburner for fan curve? If not try to uninstall afterburner and hit it with load , I think they should start spinning around 60-65c
                                          WHIRO
https://linustechtips.com/topic/1144035-gpu-fan-not-spinning/#findComment-13207252
