18 minutes ago, KoolkatBrianYT said:
Like one of those computers built into a desk?
really like the picture, not those that fits in to a PC case
like this but with a USB 20 pin : https://www.amazon.ca/Plugable-Port-USB-Power-Adapter/dp/B075NMVGP7/ref=sr_1_18?keywords=usb+3.0+hub+to+motherboard&qid=1578677451&sr=8-18
https://linustechtips.com/topic/1144012-question-on-usb-hubs/#findComment-13205234
29 minutes ago, KoolkatBrianYT said:
in the picture on amazon picture, it looked easy to take it away from the plastic shell, what are you going for?
I dont want to tear it appart ... I just want to use double face tape and stick it on the under side or on the side of my desk but i dont want it to come with a USB connector to plug into the motherboard
https://linustechtips.com/topic/1144012-question-on-usb-hubs/#findComment-13205333
