This is a brand new build. I’m having a issue where no matter what I can’t get it to post. Used pc part picker when planing out my purchases and it said no issues with compatibility.
Parts-
Processor: Amd Ryzen 7 3700x
Motherboard: Asrock x570 phantom gaming 4
Memory: G.Skill Ripjaws 3600mhz 16gb x2
Psu: corsair vengeance 750 W
Storage: Samsung 250 Gb m.2 nvme
Gpu: Rtx 2070
It has no post code beeps on the mother board but the cpu and Dram lights are on.
I have tried re seating the ram and processor,  I have tried different orientations and only using 1 stick. I have also tried using some other ddr4 8 Gb ram at 3000mhz forget the model as it was a friends. I have triple checked all power connection, re seating them and making sure they are all in the right location.
I have the HDMI plugged into to gpu as I know amd doesn't have support for on board graphics.
If anyone could help me figure out what’s going on or what I should do that would be a big help thanks.
https://linustechtips.com/topic/1143861-no-post/
