You will probably have to find the RGB software for the fans to change the color, and plug the RGB connectors into your motherboard/an RGB controller.
Specs: CPU: AMD Ryzen R7 3700X @4.4Ghz, GPU: Gigabyte RX 5700 XT, RAM: 32 GB (2x 8GB Trident Z Royal + 2x 8GB TForce Vulkan Z) @3000Mhz, Motherboard: ASRock B550m Steel Legend, Storage: 1x WD Black 1Tb NVMe (boot) + 1x Samsung 860 QVO 1Tb SSD (storage), Case: Thermaltake Core V21, Cooler: Noctua NH-D15
https://linustechtips.com/topic/1143645-i-need-help/#findComment-13201733
