I have 4 ports ports for my fans in my motherboard. I’m using 3 for my front fans and one for my cpu cooler. I’m going to get an h100i and get 3 fans for it and rear exhaust. How would I do that if I only have 3 fan ports in my motherboard. I have a lighting node core if that helps and the 3 fans I’m going to get are sp120 rgb pros and the ones preinstalled in my case are sp120 rgb pros two.
https://linustechtips.com/topic/1143482-fans/
2 hours ago, Adsome2007 said:
Can yo have more than one fan controller in one pc
Yes, you can but that might be a hassle to deal with. When it comes to fan control, do whichever is most convenient for you.
Why are you getting 3 fans for the H100i when it's just a 240mm?
https://linustechtips.com/topic/1143482-fans/#findComment-13203075
Two for the h100i and one for rear exhaust
https://linustechtips.com/topic/1143482-fans/#findComment-13207628
