GPU Upgrade
Solved by Crunchy Dragon,
1 hour ago, AreUSure said:what do you mean?
btw i think that my i5-7500 can handle the 1080 well, the only difference between the i5-7500 and the i7-7700k is that it has higher ghz than the i5 and it has +2mb cache and its overclockable thats it.i am gonna get some sleep, good night.
No, the i5-7500 isn't as good as the 7700K. The 7700K has better singlethreaded and multithreaded performance, as well as hyperthreading, on top of having more cache and being overclockable. You'd probably see a bottleneck at 144Hz with a 1080 and an i5-7500, whereas it's not as likely if you had a 7700K.
What I mean is, it can't hurt to redo the thermal paste on your CPU.
