Hey group!
I'm looking for a case recommendation.
I'm planning on building an HTPC/ NAS from older parts and a bunch of NAS drives
The case must be as silent as possible and fit a GPU, 6 3.5 drives and an SSD. Ideally it's a medium or small from factor that support a 2400 rad.
I'd rather spend my money on hard drives instead of glass and stamped aluminium so keep buy price near or under 125$ USD or tell me if I want my cake and eat it.
I got
-ROG STRIX X-370 (regular sized Mobo)
-Ryzen 7 1800X
-EVGA GTX 980ti
-WD Blue 1Tb SSD for OS and a few games
-Deepcool Captain AIO
Still need
-8 or 16 gigs of RAM (yet to buy, looking for used)
-Iron wolf 6Tb in raid 5 (6 planned in total - yet to buy)
-Case (need your input)
-750 watt PSU (yet to buy)
Ideally you have first or second hand experience with the case you will recommend.
CPU Ryzen 5900X - Motherboard Asus ROG STRIX X570-E - RAM 16GB of G.SKILL NEON 3600 -
GPU EVGA RTX 3080 XC3 - Case Mastercase H500p mesh - PSU Seasonic Focus Gx-850 -
Corsair MP600 NVME 1 Tb, Samsung 960 PRO 500 Gb & 2 Seagate Baracuda 7200 RPM 2TB in stripe -
Display two VG27AQ 2K monitor - Cooling Corsair H150 Pro -
Keyboard G-910 W/ Romer G tactile - Mouse G 502 Hero (wired) -
Sound Logitech X-530 and Razer Tiamat headphones
Operating System Windows 10
https://linustechtips.com/topic/1143255-case-recommendations-for-htpcnas/
5 minutes ago, Quickstrike said:
Most modern cases mostly ditched 3.5" slots, might want to go for a bit older model
also not sure you want a silence focused case with all of the heat that will come from that CPU/GPU
https://pcpartpicker.com/product/wNrG3C/cooler-master-case-nse400kkn2
You can get noise pretty low with fan controls on a mesh case anyways.
