I have a NZXT Switch 810, so I was thinking of getting a 420mm radiator, a white Swiftech Apogee, and a Laing D5.
I would probably get a tube res because they're more secure, and I might get rid of the 5.25" bays if I want to fit a 360 in the front.
I'd probably get some Bitfenix White compressions.
Specs:
CPU:  Intel Core i7-3930K 3.2GHz 6-Core Processor  (£422.40 @ Amazon UK)
CPU Cooler:  Zalman CNPS11X Performa CPU Cooler  (£27.95 @ Scan.co.uk)
Motherboard:  ASRock X79 Extreme3 ATX LGA2011 Motherboard  (£143.48 @ Dabs)
Memory:  G.Skill Trident X Series 16GB (2 x 8GB) DDR3-2400 Memory  (£139.99 @ Amazon UK)
Storage:  Samsung 840 Pro Series 128GB 2.5" Solid State Disk  (£92.57 @ Amazon UK)
Storage:  Western Digital Caviar Black 2TB 3.5" 7200RPM Internal Hard Drive  (£112.80 @ CCL Computers)
Video Card:  MSI GeForce GTX 780 Ti 3GB Video Card  (£529.25 @ Ebuyer)
Sound Card:  Asus Xonar DGX 24-bit 96 KHz Sound Card  (£23.90 @ Overclockers.co.uk)
Case:  NZXT Switch 810 (White) ATX Full Tower Case  (£138.97 @ Scan.co.uk)
Power Supply:  Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£68.98 @ Amazon UK)
Monitor:  Asus PB278Q 27.0" Monitor  (£449.12 @ Scan.co.uk)
Other: 42" Samsung 3D TV
Other: AKG K702 with anniversary edition pads
Total: £2149.41
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-11 17:33 GMT+0000)
Budget: €350+
Possible config (Friend came up with it):
TOTAL: £330
https://linustechtips.com/topic/114237-watercooling-loop-help-needed/
I'd suggest is getting better fans for the rad.  Noctua, Noiseblocker, Akasa all make good 140mm pressure optimized fans.  there are prolly others but this is all I can think of at the moment.  Most good 140 fans are 4 pin pwm fans, you can still run them on a 3 pin fan controller, so don't let that be an issue.
I'd also suggest a can controller with more watt's per channel.  the one you have linked only has 7 watts.  Lamptron makes fan controllers with 30+ watts per channel.  and to go with this, get a 3-1 fan splitter so you can run all 3 rad fans on 1 channel.
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
those are good, thats what I have on my 420 rad
  • 3 months later...
