I'm building this computer, but I need help chosing a case, GPU and storage for it. It can't exceed 260€ (not by much, at least). It will be used for gaming purely, I don't mind playing games at low settings as long as they run smoothly. This is what I have:
GIGABYTE GA-A320M-S2H Micro ATX   50,90 €
 AMD Ryzen 3 2200G   90,22 €
GPU   - €
Crucial Ballistix Sport LT 8GB DDR4 RAM 3200    49,03 €
Thermaltake Smart RGB 500W   47,89 €
Storage   - €
Case   - €
This leaves me with around 260€ for the parts I need.
I'm also open to suggestions regarding other parts, keep in mind this is my first ever PC build and what I have is mostly taken off youtube. Thank you!
https://linustechtips.com/topic/1142352-need-help-finalizing-a-build/
500 is plenty for mid range gpu.
Get a RX5700 or RTX2600 for $350.
A 512gb SSD for the boot drive ($50), a 2TB HDD for game ($50).
And $50 for the case.
The 500€ include what I already have, maybe I should have made that clearer
Your best bet would be scanning local 2nd hand markets. You're not going to find any decent new hardware at that price point.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
1 minute ago, triu1 said:
What should I look for though?
Whatever you need. I don't know what you will be able to find.
For the GPU I would look for used RX570. For case and storage, the best you can find.
