Case fans, Where do I connect them on the motherboard?
Solved by NotSoEpicMods,
That adapter will run the fans at 100%. Most motherboards these days control the fans to some extent so if you can plug them into the motherboard I would do that.
Featured Topics
Somerandomtechyboi ·
Suryavardhan Singh Rathore ·
Posted in New Builds and Planning4 -
Caveman0407 ·
Posted in Laptops and Pre-Built Systems7 -
akio123008 ·
Posted in Home Theater Equipment4 -
KornyJ ·
1
JamZam ·
Posted in Troubleshooting10 -
1
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
