Specs:
asus rog strix x570-i
ryzen 9 3900x
corsair sf750
corsair dominator platinum rgb 2x16gb 3466mhz
msi gtx 980 4g (test gpu)
samsung m.2 960 evo 1tb (shouldnt matter)
Hi, i set up a testbed today just to see that all the components are working properly and i get no post. According to asus RAM support page my dimms are not listed which might the problem. What i've tested:
- 1 or 2 ram sticks
- gpu with or without PCI-e cables
- keyboard / no keyboard
- hdmi to gpu / motherboard
- dvi to gpu
Everything lights up, on the status LEDS i get the following (in this order):
- yellow static DRAM
- red static CPU
- white GPU
- green BOOT
any help i can get would be awesome :)
https://linustechtips.com/topic/1141754-new-system-no-post/
Not 100% sure but is your board supporting 3rd gen Ryzen out off the box or need bios upgrade before that. That may be your problem
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1141754-new-system-no-post/#findComment-13186893
I removed the cooler and it turned out that the stock cooler had excessive amounts of thermal paste that was pushed out on the sides and into the socket. I'm sending both the CPU and Motherboard back to the retailer so i don't risk any warranty.
However the 3900X is supported on all PCBs and BIOS 0268 but i'm not getting any post so i couldn't check which version i had
https://linustechtips.com/topic/1141754-new-system-no-post/#findComment-13187022
