Wireless charging is a feature of the device, not the OS. So you really need to be looking at that instead.
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
The thing you need to look for is called the Qi standard. But as Roderick said the feat is hardware side so you need to check your devices if they can do it.
CPU: Intel Core i5-4670k Mobo:MSI Z87-G43 RAM:Corsair Vengeance Pro 8GB 1866MHz SSD:Samsung 840 120GB GPU:Gigabyte GTX770 2GB PSU:EVGA NEX650G Case:Fractal Design Define R4 Cooler:Corsair H80i
Is there a universal wireless charger that works with all Android devices? Or at least a dock-like thing that doesn't require that much effort plugging your device into?
all Android devices? No. Only certain ones have Qi charging capability, or could be modified to have it (either through a case, or with a pad between the battery and back cover like the S4.
"Rawr XD"
