Hello I’m currently thinking about building a Mini Form Factor PC that can play rocket league, rust, rainbow six siege, and other games. I’ve been looking around and I’m kinda lost. Can you guys give me some Mini form factor PC build ideas. ITX motherboard would be the goal.
https://linustechtips.com/topic/1140848-mini-form-factor-build-help/
you will certainly need a discrete GPU for these games
before that pick a case you like first, mini ITX is very tricky in parts clearance
eg: SilverStone SG13, cube case ... if you like it
I’m looking at the Lian Li Tu150
1 minute ago, MaplesGamer said:
Lian Li Tu150
oh well, theres really no hard clearance limitations on these shorter tower.
you cant really go wrong with ryzen 2600/2700/3600 and gtx1660 super (1080p 60 fps gaming) or higher with sapphire rx5700xt pulse/ nitro
17 minutes ago, MaplesGamer said:
I like that, I might go for that setup. It’s solid. What cooling solution would you use to cool a 2600 or higher in a small form factor build.
Noctua NH-L9a-AM4 33.84 CFM CPU Cooler
SFF build ?
CPU | Intel i9-10850K | GPU | EVGA 3080ti FTW3 HYBRID  | CASE | Phanteks Enthoo Evolv ATX | PSU | Corsair HX850i | RAM | 2x8GB G.skill Trident RGB 3000MHz | MOTHERBOARD | Asus Z490E Strix | STORAGE | Adata XPG 256GB NVME + Adata XPG 1T + WD Blue 1TB + Adata 480GB SSD | COOLING | Evga CLC280 | MONITOR | Acer Predator XB271HU | OS | Windows 10 |
