Hi Guys, I Just Had A Quick Question.
I Have Been A PC Gamer, Mainly Laptop, For Years. I Have Purchased A PS4 And The Internal Fan Isn't Doing Too Well. So I Purchased A Fan To Help The Exhaust Out Of The Back.
So Heres The Question.
Does Using Spacers Or Felt Pads To Elevate The Playstation A Couple Inches Off The Desk Help Any With Cooling? I Understand That It Does Provide A Little Less Dust Into The Fan But It Just Seems Excessively Hot Right Above The CPU.
It Is An CUH-1215.
https://linustechtips.com/topic/1140781-ps4-elevation-does-it-work/
It Is An CUH-1215.
Well I'm not sure you can always try to do that, it usually helps, but ps4's are known to get really hot so maybe it's normal...?
"Rise red as the dawn" - Scarlet Guard motto (Red Queen Series)
