ive recently been trying to get my m.2 ssd to boot windows but when I go to my bios it doesn't show recognize it until I got into boot options and all it says there is wd 500gb, when I click it to boot off it it gives me a cursor flash 3 times at the top left corner then returns to bios ive tried both m.2 locations on my board and gotten the same result using a asus z370 e gaming motherboard.
https://linustechtips.com/topic/1140485-system-wont-use-m2/
So you want to install windows on it or it’s installed already and you want to boot to it?
https://linustechtips.com/topic/1140485-system-wont-use-m2/#findComment-13176097
