Hello. I have a problem with my computer. I can connect my main screen with an displayport and its working fine. I have to more screens and these are connected with hdmi and dvi, but they say no signal. It was working fine the day before. They just say no signal and go out. (all screens are connected to a Gtx 1080 ti).
https://linustechtips.com/topic/1139379-hdmi-and-dvi-issue/
6 minutes ago, Papple said:
Hello. I have a problem with my computer. I can connect my main screen with an displayport and its working fine. I have to more screens and these are connected with hdmi and dvi, but they say no signal. It was working fine the day before. They just say no signal and go out. (all screens are connected to a Gtx 1080 ti). It is only the screens there is a problem with.
Did you set up the displays in windows?
https://linustechtips.com/topic/1139379-hdmi-and-dvi-issue/#findComment-13167603
1 minute ago, Papple said:
yes before, but they aren't showing up
Should make a linux USB and see what happens running Ubuntu off it.
May have some strange hardware issue if there's still a problem.
are the monitors selecting their source properly?
You could try unplugging everything and taking out the GPU so everything can discharge for like 30 minutes before trying it all again.
https://linustechtips.com/topic/1139379-hdmi-and-dvi-issue/#findComment-13167615
It was working the day before and i unplugged the hole pc cause i moved over to my friend. And when i came back I got this issue. The monitor are on the right setting.
https://linustechtips.com/topic/1139379-hdmi-and-dvi-issue/#findComment-13167633
No idea then, your PC may just be cursed
https://linustechtips.com/topic/1139379-hdmi-and-dvi-issue/#findComment-13167742
