Someone please help
Go to solution Solved by kirashi,
3 minutes ago, dome3731 said:
Hello, thank you for taking the time to help, I backed up my phone data to my PC and now I have these .bak files which I don't know how to put back onto my phone, please help.
As mentioned above, we're gonna need a lot more details in order to know where to even begin.
Just now, dome3731 said:
I have a xiaomi mi 4c I used the built in back up and then copied that to my pc into a folder.
All the guides I'm finding on Xiaomi's website indicate you should have a folder named by date that you just copy back to a specified folder on the phone, then restore from. Not really sure why it gave you a .bak file, so you might need to reach out to Xaomi for more details.
https://c.mi.com/thread-1412906-1-0.html
What phone? how did you backup your phone? what phone are you trying to restore these to? There is no binary answer to everything, provide details.
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162891
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162894
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162895
Xiaomi mi 4c built in backp up and restore tool and then I copied that to my PC and I have the .bak files in a folder on my windows 10 PC.
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162901
What is the general solution to this if you know?
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162905
No idea, I don't own a Xaomi phone, so I don't want to direct you to do something that might render your backups unrecoverable or worse, cause data loss. Xaomi is responsible for supporting their software, so contacting them would be your best bet. May as well as reach out to them for support while you await further replies on the forum.
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162914
I have looked at the thread you sent and I will try that and I also contacted xiaomi, thank you very much for taking the time to help me. I really appreciate it.
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162919
No problem, happy to help point you in the right direction. I'm heading off to sleep now, but did find a couple other links that may be of use to you.
https://forum.xda-developers.com/xiaomi-mi-3/help/help-how-to-bak-file-t2883318
https://in.c.mi.com/thread-2540-1-0.html
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162926
Thank you.
https://linustechtips.com/topic/1138752-someone-please-help/#findComment-13162927
