This is my second time working with Ryzen Wraith Spire cooler. I had no issues the first time. Screws installed perfectly into socket.
However, while installing the cooler this time, the screws will not move. I can turn and turn and turn, but the screws will not move down. They just spin uselessly in the air.
Yes, I removed the bracket that was originally on the mobo. I've included a picture. The screws just float above the socket.
Picture of the issue
Someone suggested that I screw counterclockwise until I hear a thud, but that did nothing. Another suggested I push forcefully down on the screws, but that didn't work. Is this cooler defective?
I can't really remove the cooler now as is either, as the thermal paste has been applied and the cooler is stuck quite well. If I can't get the screws to move down, how can I remove this cooler? It's pretty stuck. Is there another way to heat the paste to remove it?
Edit: LOL, sorry about my profile pic. It's associated with my Steam account. Just a joke more than anything.
Edited by smellycatbutts
https://linustechtips.com/topic/1138721-cpu-cooler-installation/
Pull everything to do with the cooler apart and try again. Usually something is not seated correctly when this issue happens and you have to redo it to get it to work.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
How would I do that? The cooler is completely sealed. Is there some way to heat up the thermal paste so it will loosen its vice like grip?
Just slowly pull the cooler off. I find don't pull straight up, pull like your peeling it off. start on one side and pull at an angle to the other slownly. The paste does tend to stick quite well. Just make sure you have thermal paste on hand to apply when you put it back together as you'll need to clean the cpu heatspreader and the cooler bottom.
Also I just looked at the picture again, it looks like they are held by springs. Did you make sure to push down on the screw when turning them?
Sometimes (Not recommended with new hardware but can work (not responsible for any damages)) I've actually taken the cpu out of the socket along with the cooler and used a screw driver to pry them apart.
RAINBOWS!!!
  Reveal hidden contents
I've pushed as hard as I reasonably can. This is my second time installing this cooler. My other build didn't require this amount of force.
Here's a short video of what I'm talking about. I had to use my other hand to hold the phone, but even with proper force applied to the screw driver, and holding the cooler, the screws will not move down into the socket.
hmmm yeah something is definitely wrong there. That means probably an RMA is going to be in your future.
RAINBOWS!!!
  • 2 years later...
