Hi!
I need help fixing my pc. It is an intel i5-8600k with an gtx 1080 graphicscard and this settup has worked flawless for a long time up until now.
Problems:
- Usually high process usage ingame, but also regular tasks like opening google.
- Low FPS in a majority of games, usually between 70-80 compaired to a solid 144+ fps before.
- In whole a very unsmooth experience, especially compaired to before.
- Games like battlefield shows warnings signs like package loss, Latency variation and low fps.
I feel like I've really tried everything. Reseting Windows, Hardware checkup etc... If you have any clue of what this could be, anything would help.
https://linustechtips.com/topic/1138469-pc-problems-any-help-appreciated/
2 minutes ago, Lorant said:
Resetting Windows?  Not a full re-install?
Did you run a full malware/virus scan?
Might even have some drivers that are corrupted, Resetting Windows won't always fix that.
I did an re-install of windows and I've ran multipule Malware/virus scans but nothing seems to work. I have updated the drivers to the latest version.
Maybe a hardware issue then?  A full reinstall of Windows and drives should have you on the right track.
Package loss on Battlefield?  Internet wired or wireless?
Can you test internet?
It is wired. I have been using the same internet since when I built the pc and I don't think the high cpu usage and the low fps can be connected to the fps?
I was reading your line about packages ( think you mean packets) and latency, those are internet issues.
If you're playing online games, internet issues can cause fps issues as your machine is waiting updated info.
Ah ok. Yeah my internet is very fast but not always so reliable and I though that sign had somthing to do with the pc... But the issue is present even in desktop mode. Thanks for replying!
