Hey,
I got another problem with my new PC build: On my motherboard there are two connectors: 1x 8-Pin and 1x 4-Pin Connector. I only got a cable which is split into 2x 4-Pin-cables. How do I have to plug the cables in? I got a Ryzen 7 3700X with 65W TDP.
Thanks for your help and merry Christmas everyone!
https://linustechtips.com/topic/1138459-cpu-power-cable/
1 minute ago, BaDeyy said:
Both cables in the 8-Pin one?
The 4+4 cable should click together to form an 8pin connector. Insert that in to the 8pin socket.
https://linustechtips.com/topic/1138459-cpu-power-cable/#findComment-13160436
