Hi!
So I’m building a new pc and I have already chosen all the parts but I’m not sure if I have made a good decision. I have some older parts I have from my previous build, such as: psu: 500w be quiet system 9 and gpu: GTX 1060 6gb, and they still work very well.
The parts I have chosen so far:
CPU:
AMD Ryzen 2700
MOBO:
Asus rog b450-f gaming
RAM:
Corsair vengeance rgb 16gb ddr4 3200MHz
Storage:
Samsung evo 970 500gb
Case:
nzxt 510
If you have any suggestions or comments please do not hesitate to comment:)
https://linustechtips.com/topic/1138248-ryzen-build/
There are better motherboards in the market at that price (e.g. tomahawk). The 2700 is a good CPU, I would probably get a 3600 over a 2700 though.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1138248-ryzen-build/#findComment-13158971
4 minutes ago, Pc kid said:
I chose the 2700 because the higher core count, good for video editing.
Multicore difference between 2700 and 3600 is not that wide.
https://youtu.be/7AbNeht4tAE?t=1320
Look at this and you decide if worse single core performance is worth it for slight gains in multicore. You know your workload better than us.
Unraid Server
https://linustechtips.com/topic/1138248-ryzen-build/#findComment-13158996
7 minutes ago, boggy77 said:
Corsair 510, inland premium, sabrent rocket, silicon power a80, teamgroup 34, hp 920/950, adata 8200
I chose the Samsung 970 evo because it had fast upload and download speeds.
would the ssd’s you recommended have the same/similar performance.
https://linustechtips.com/topic/1138248-ryzen-build/#findComment-13159010
