They are compatible, whether they are the right purchase or not nowadays is highly debatable.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13158962
PCPartPicker Part List
CPU: AMD Ryzen 7 3800X 3.9 GHz 8-Core Processor  ($419.99 @ Amazon Canada)
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler  ($159.99 @ Amazon Canada)
Motherboard: ASRock X570M Pro4 Micro ATX AM4 Motherboard  ($245.95 @ Vuugo)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 Memory  ($164.99 @ Newegg Canada)
Total: $990.92
Generated by PCPartPicker 2019-12-25 17:36 EST-0500
3800X has much higher 0.1% and 1% lows than the 9700k, other than being much cheaper. 3700X is slightly cheaper too for almost the same performance but it seems you have the budget for it. The 9700K might have higher max fps, but it's not worth it imho.
Kept the MicroATX size of the motherboard. Maybe go ATX if the case is big enough.
Rest of the build is pretty much the same. Put a RGB version of the H100i.
Overall you save quite a few bucks, other than having a better overall component between gaming and other uses in my opinion.
Unraid Server
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13158986
Total: $990.92
Well the h100i IS rgb controlled maybe u didnt see that.and intel is best for fps i will ONLY be gaming with a 2080ti so i need maximum fps
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13158993
Yes, just the logo.
Maximum fps isn't exactly optimal when you have much lowers 1% and 0.1%, which means more stuttering. You do you.
Unraid Server
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13159006
The largest difference with Ryzen is that every cpu though their lineup gets multithreading/hyperthreading which you no longer get with Intel's current lineup. Not to mention they're like $100~ cheaper, perform similarly and come with a free usable cooler.
With hyperthreading on my 1st gen i7-980x 6c/12t overclocked to 4.5ghz, I'm able to match the Cinebench R15 performance of the stock 9th gen i5 9600k which is a brand new 6 core but only 6 threads. Intel has really kneecapped this generation and in a few years is going to be bottlenecking due to lack of threads the same way non-hyperthreaded quad cores have been for a while. Yeah the Intel might get 2-3% better frames in older games today but the comparable Ryzen cpu is going to be getting far better frames in games in the coming years.
None of this makes the hardware particularly bad though, just poor value and will be obsolete much sooner. As far as becoming obsolete sooner, the rumors for 10th gen include things like hyperthreading across the whole lineup and another increase in core counts which would really burn anyone who bought the 9th gen short of the 9900k.
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13159041
dont really care about rgb
13 minutes ago, Nocte said:
Yes, just the logo.
and I wasted several nights losing sleep watching benchmarks seeing the 9700k and the 9900k always in first first 9900k (other than those super cpus'd with 16 core 32 thread shit)
and the 9700k came 3rd or 5th max but always better than amd
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13159042
Then you can get much better RAM for the price.
Unraid Server
https://linustechtips.com/topic/1138246-pc-build-help/#findComment-13159071
