I bought a Hydro Series H100i RGB PLATINUM SE 240mm Liquid CPU Cooler and when I try to attach the LL120 fans (Included) with the long Screw that was included the screw looks like it is going to bend the fins if I push it any further. Is this normal? What is the coreect Screw to use. In the video (Attached) it dosent say to us washers in the front on the fans but on their website you can clealy see they do... what do i do? Thanks! Merry Christmas!
https://linustechtips.com/topic/1138145-aio-question/
The screws should stop before the fins on the rad. If you screw into the fins on the rad itself you can puncture it and spring a leak
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1138145-aio-question/#findComment-13158635
