Can I mount a 280mm AIO in Lian Li Lancool II Case
Debz
Hi guys, title says it all. I am planning to buy this case but I have a 280mm aio, NZXT Kraken x62. I am wondering if can i mount it on the top.
Download the manual of both and check it, not that hard to asks for help......
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I dont think so tbh
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
40 minutes ago, Ben17 said:
I dont think so tbh
Front supports 3 X 120mm or 2 X 140mm
Top: supports 2 X 120/140mm
So yes you should be able to fit a 240/280/360 AIO in the front and a 240/280mm AIO on top.
So you should be able to fit a 240/280/360 AIO in the front and only a 240 AIO on top.
Below pic is snipped from Lian Li website
But you need to make sure it clears your mobo, memory and cables
Edited by Boyohan
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: In Win D-Frame   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
That's for the fan mount. Official specs say top supports up to 240mm radiator, 280mm may interfere with other parts of the case (radiator is an additional 25-30mm compared to plain fan, plus the tubes).
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
@jj9987
Ye I just double checked this and you are correct.
A 280mm rad will interfere with the memory when mounted on top.
@Debz
There you have it.
240mm on top
240mm/280mm/360mm in the front.
Edited by Boyohan
25 minutes ago, Boyohan said:
Any special reason why you want a 280mm on top ?
You could go for the Kraken X52 instead.
He already has the kraken
Thanks for the correction I thought he said 380 not 280 sorry
Hi guys. Merry Christmas. Do you have any suggestions about a case for 280mm aio at the top? maybe a white case would be awesome. btw my GPU is MSI RTX 2070 Super gaming X trio.
Some examples from top of my heart: NZXT H700/H700i, Fractal Design Meshify S2, Define S2
I will check this out. Thanks
  • 1 month later...
I'm looking at AIOs on the LanCool II case.  What did you end up installing???
I purchase Cooler Master H500p Mesh white. My NZXT X62 did not fit in LanCool II
  • 10 months later...
Old thread but yes you can apprently this guy got it working https://au.pcpartpicker.com/b/vbx6Mp#cx3816965 (pcp List)
