14 minutes ago, Gannam said:
Currently I have "3200" speed memory on my 4.3 overclocked cpu, what are the options for a upgrade, and the performance increase that would bring.
Any tips would be appreciated!
There really isn't any upgrade to be had. 3200 MHz is about the sweet spot, sure a little faster would be a little faster on paper, but you would see no difference at all, especially not for the price. We would be talking 1-2% gains at BEST, and 0% most of the time to be honest.
https://linustechtips.com/topic/1137589-memory-for-ryzen-2700x/#findComment-13154381
try OC your current memory kit even more. It's not the like the 2700X is all that capable in memory anyway
Desktop benching:
https://linustechtips.com/topic/1137589-memory-for-ryzen-2700x/#findComment-13154406
1 minute ago, Gannam said:
Couldn't quite get it past 3200, but also i haven't adjusted voltage, not knowing how to safely do that.
SOC to 1.1V, memory voltage to 1.45V (sometimes higher doesnt mean better tho), see if you can go higher frequency while keeping DOCP enabled
Desktop benching:
https://linustechtips.com/topic/1137589-memory-for-ryzen-2700x/#findComment-13154519
