Not able to setup my PCI-E bluetooth adapter
epicAdapter
Hey guys,
So I got as a present a QCA-9377 and the interface is a PCIe 2.1 and I got a GA-AB350 motherboard.
I cant figure out how to install this device. I tried this slots.
I imagine that my motherboard doesnt support 2.1 is there a way I can surpass this problem without having to buy another adapter? And if no, which kind of interface should the new adapter have?
Thanks for taking your time with this question!
3 minutes ago, emosun said:
did you install the driver for it
oh sorry I wasnt very clear!!
Physically it didnt fit!
This side of the chip (img1) is bigger then this side of the PCI-e on the motherboard (img2)
thats a mini pci-e card , you need a mini pci-e port on your board for that . you'll need a passive adapter
Thank you very much for your help!
Would this work
I'm not sure if the Bluetooth will work though, they usually require USB support.
I personally would have gone for something based on the Intel AX200, or if all you want is Bluetooth not WiFi, a USB Bluetooth dongle.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
