VPN doesnt work over MESH-System
David.A
I have in my house 1 Router and 2 MESH-Routers. I use VPN for work. Now when I am connected to the normal Router with my Laptop I can use VPN. When I am connected to a MESH-Router via Ethernet I can also use VPN. However when I am connected to a MASH-Router via Wifi the VPN doesnt work. This only occurs on my Laptop. On my iPad for example it works normal. How can I fix this?
They may have an option selected within the web accessible firmware that is set to block VPN connections by default. Your iPad could be using alternative protocols to bypass the issue, where your laptop doesn't. Do you know how to access your firmware? Plug your laptop via Ethernet into one of the mesh routers, there should be a label that will tell you what the default IP address is and the login credentials. If the information on the label doesn't work let me know.  The default IP address could have changed.
